how to monitor performance of scripts/UI
Solved2.26K views5th March 2024#automationscript LCA
Tim Vandenbruwaene [SLC] [DevOps Member]2.29K 28th February 2024 0 Comments
I would like to monitor how much each step takes to execute, starting from clicking a button on the Visio UI/LCA to the actual update on the UI.
So in my case typically operator clicks a button, triggers a scripts, script executes a couple of functions and when the script finishes it triggers an UI update
Is there a framework available or recommended implementation so that it's possible to monitor the performance of each of these steps over.
Creating for example a LCA to visualize this.
In the documentation I found following link: Namespace Skyline.DataMiner.Net.LogHelpers | DataMiner Docs,  would that be usefull in this case?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 5th March 2024
Matthijs Favorel [SLC] [DevOps Advocate]2.63K Posted 29th February 2024 0 Comments
Hi Tim,
There is indeed a framework available, see the details here: https://github.com/SkylineCommunications/SLC-AS-ScriptPerformanceAnalyzer
There is a nuget available to implement in the scripts, and a package with an ad-hoc data source and Low-Code app to visualize and investigate the performance of the scripts.
