How to mask alarms from a single interface?
Solved2.99K views11th July 2023
Jorge Sienra [SLC] [DevOps Member]375 10th January 2022 0 Comments
The idea is to be able to quickly mask and unmask alarms coming from one or more interfaces in a device, without having to mask the entire device.
Jeroen Neyt [SLC] [DevOps Advocate]2.61K Posted 21st January 2022 0 Comments
Here's an example on how you would mask a row in a table through DataMiner Automation:
First you'll have to setup the helper to communicate with the back-end.
var helper = new DMAObjectRefTreeHelper();
helper.SetupHelper(Engine.SLNetRaw.HandleSingleResponseMessage);
Then through that helper you can mask the row by stating which object needs to be masked and which mask info needs to be applied.
helper.ChangeMaskInfo(new DMAObjectRefTree(
new RowID(
162, // DataMiner ID
350, // Element ID
1500, // Table ID
0, // Column Index
"eth0")), // Row Index
new MaskInfo()
DoMask = true,
MaskType = MaskType.UntilUnmask,
Reason = "Maintenance"
new CPECrawlerConfiguration());
Unmasking can be done by setting the DoMask property to false and the MaskType property can be used to apply a different kind of masking strategy.
In the example the object will be masked until it's later manually unmasked again, but there's also the option to mask it for a certain period of time (MaskType.UntilTimeElapsedOrUnmask) or automatically unmask it if an alarm would be cleared again (MaskType.UntilClearanceOrUnmask).
Jeroen Neyt [SLC] [DevOps Advocate] Answered question 21st January 2022
