How to link UI block buttons to actions (C# Automation scripts)
Solved2.26K views8th September 2023Automation script C++ uiblockdefinition
Curtis Baiden [DevOps Advocate]606 6th September 2023 0 Comments
I would like to get a bit more info on how to link UI block buttons with actions, just to get a better understanding.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 8th September 2023
Amer Hodzic [DevOps Member]784 Posted 6th September 2023 4 Comments
Hi Curtis,
If you want to trigger Qactions all you have to do is set parameter to 1 like so:
ele[0].SetParameter(20100, 1); // Trigger Button
or the event trigger that when a ui button is pressed to do a certain action would be so:
dialog.NextButton.Pressed += (sender, e) => Button_Pressed(sender, e, dialog);
public void Button_Pressed(object sender, EventArgs e, HelloWorldDialog dialog)
//Some Actions
Hope this helps.
Amer Hodzic [DevOps Member] commented 6th September 2023
Sorry only seen now that you want it for UI blocks but the anwser I gave was for Widgets.
Here is the link to where it explains it in the Docs with an example:
https://docs.dataminer.services/develop/api/types/Skyline.DataMiner.Automation.UIResults.WasButtonPressed.html
Curtis Baiden [DevOps Advocate] commented 7th September 2023
Thank you Amer, I also have another question. How do I get the result from a checkbox list option,
Amer Hodzic [DevOps Member] commented 7th September 2023
For UI blocks you will find it here:
https://docs.dataminer.services/develop/api/types/Skyline.DataMiner.Automation.UIResults.GetChecked.html
For widgets:
IEnumerable test = dialog.CheckBoxList.Checked;
Thank you, all done now.
