How to keep a variable in memory between automation script runs?
Solved2.03K views12th July 2024automation scipt Memory
Mieke Dryepondt [SLC] [DevOps Advocate]4.27K 11th July 2024 0 Comments
With connectors - qactions it is possible to keep a variable in memory between 2 executions of the qaction.
This is also possible for ad-hoc datasources.
How can we do this for Automation scripts?
And when there is no built-in mechanism by DataMiner, could this still be accomplished somehow?
E.g. a static concurrent (thread-safe) dictionary or something alike
Tom Waterbley [SLC] [DevOps Enabler] Answered question 12th July 2024
Dominik Kosteletzky [DevOps Advocate]773 Posted 11th July 2024 0 Comments
You can use MEMORY FILES to store values, which will also survive reboots.
https://docs.dataminer.services/user-guide/Advanced_Modules/Automation_module/Designing_Automation_scripts/Script_variables.html#creating-a-memory-file
Ben Vandenberghe [SLC] [DevOps Advocate] Selected answer as best 11th July 2024
