How to install DM using STaaS without an organization?
Solved1.46K views18th March 202510.4 Installer installer STaaS
13
Sebastian Ulloa [SLC] [DevOps Advocate]2.34K 17th March 2025 0 Comments
Hi community,
When running the installer of a self-hosted DM that uses STaaS, it normally asks for an Organization API key.
However, if I'm a brand-new user of dataminer.services, I wouldn't have an organization associated with my account and therefore I wouldn't have a key to provide to the installation wizard.
What are users expected to do in this scenario? Perhaps create a temporary DaaS so an organization is created?
Thank you!
Sebastian Ulloa [SLC] [DevOps Advocate] Selected answer as best 18th March 2025
Baptiste Pattyn [SLC] [DevOps Advocate]5.86K Posted 18th March 2025 0 Comments
Hello
this is indeed something that can (and will) be improved upon from our side as for now there is no easy way to create a new organization.
A workaround is to indeed go to dataminer.services, click on "Add a DataMiner System", select "DataMiner As A Service" and then under the organization dropdown you can select "Create New" (see picture). This will open up a popup to create a new organization. Once you have clicked the "Create" button you can just close the browser window, you will have your organization. From there you can go to admin.dataminer.services and create the necessary key.
I hope this helps!
