How to get row value of an element by using a row value from another element
Solved1.41K views12th January 2022
joel Joly489 12th January 2022 0 Comments
Hello
Does anyone know how in Visio view, to get the value of row in a table, using the result of row from another table in different protocol ?
I want to get a row table of each child element from a manager element
the result is the draft image just above and it’s OK, I can see the name of each element managed
What I want now is to get some values of each child element (let say the temperature) like in the shape on the right side
I tried many  things like above
[param:[param:*,1802],112] doesn’t work
[param:*,112] doesn’t work even if i use a shape row child to get the name of element
I think I am not so far, but for now it’s a fail
we use this version of dataminer : (9.6.0.0-9817-CU21)
Ben Vandenberghe [SLC] [DevOps Advocate] Selected answer as best 12th January 2022
Jochen Dewachter [SLC] [DevOps Member]2.17K Posted 12th January 2022 1 Comment
Hi Joel
You’re indeed on a good track by nesting placeholders. However I believe you’re missing your row indexing. First you’re dynamically generating a group shape for each row in a table. From that row you want to take the value of a column (the element name) and use it to display a parameter value (temperature).
When ‘selecting’ your element name from the table, you need to also define a row via the placeholder [tableindex]. Assuming parameter 1802 is your element name, it would look like [param:*,1802,[tableindex]]. This can then be nested to get your temperature value. I did a quick test myself and this seems to work:
Where parameter 104 is my temperature value and parameter 1003 is my column value holding my element name.
joel Joly commented 12th January 2022
Ah Yes, work like a charm 🙂
thanks a lot for your help
