How to exclude DVEs from engine.FindElements
Solved429 views24th September 2026automation scripts child elements DVEs ElementFilter FindElements
7
Adel Azzouza232 24th September 2026 0 Comments
Hello,
Using Automation Scripts, I would like to return all Elements but excluding DVEs.
I'm calling engine.FindElements with an ElementFilter, but the it does not have any property for this.
https://docs.dataminer.services/develop/api/types/Skyline.DataMiner.Automation.ElementFilter.html
var myElementFilter = new ElementFilter { DataMinerID = dmaId };
Element[] elements = engine.FindElements(myElementFilter);
Does anyone know how to achieve this?
Thanks in advance.
Adel Azzouza Selected answer as best 24th September 2026
Robbe De Ghein [SLC] [DevOps Advocate]1.51K Posted 24th September 2026 1 Comment
Hi Adel,
You cannot filter out DVEs using the ElementFilter.
You can however filter them out in the script itself, after retrieving the elements from the agent.
Element[] elements = engine.FindElements(myElementFilter).Where(element => !element.RawInfo.IsDynamicElement).ToArray();
Adel Azzouza Posted new comment 24th September 2026
Adel Azzouza commented 24th September 2026
Thank you Robbe, that was very helpful!
