How to display wind direction on Wind Rose from FT742 wind sensor
Solved2.39K views17th July 2023FT742 weather station wind direction wind rose
Robert Dunne 6th December 2021 0 Comments
Hello
I have project to get the data off an FT Technologies FT742 wind sensor. I am trying to figure out how to display the wind direction using some kind of Wind Rose. Has anyone done a weather station display before? Any suggestions?
Robert Dunne Posted 6th December 2021 1 Comment
Hi Matthijs
Thank you for your reply, yes that will do nicely. I presume you are getting the direction in degrees from your antenna rotator?
Thanks again.
Rob
Matthijs Favorel [SLC] [DevOps Advocate] Posted new comment 6th December 2021
Matthijs Favorel [SLC] [DevOps Advocate] commented 6th December 2021
Hi Rob,
I am indeed getting the position of the antenna in degrees from the antenna controller.
