How to display wind direction on Wind Rose from FT742 wind sensor
Solved2.42K views17th July 2023FT742 weather station wind direction wind rose
Robert Dunne 6th December 2021 0 Comments
Hello
I have project to get the data off an FT Technologies FT742 wind sensor. I am trying to figure out how to display the wind direction using some kind of Wind Rose. Has anyone done a weather station display before? Any suggestions?
Matthijs Favorel [SLC] [DevOps Advocate]2.63K Posted 6th December 2021 2 Comments
Hi Robert,
The below example was not for the wind direction, but for the direction of an RF Antenna, but the same is applicable.
If you get the direction from the sensor in number of degrees, you can use the Rotate shape action to rotate an arrow in a visio. Make sure the center of rotation of your shape is correctly positioned.
Alberto De Luca commented 7th December 2021
This looks great – but what if the weather station provides something like this?
Just linking, not adding the screenshot as the image might be subject to copyright:
https://www.researchgate.net/figure/Wind-rose-based-on-the-observed-wind-during-1-January-to-31-December-2014-at-Ship-John_fig6_328114515
I think VISIO supports gradient colouring offline, but could gradient be added also in an online VIEW?
Matthijs Favorel [SLC] [DevOps Advocate] commented 7th December 2021
Hi Alberto, The visual overview in DataMiner does support the gradients of Visio.
Making something like your linked picture might be some work, but not impossible.
