How to debug not starting of Process Automation after DMA restart
Solved2.76K views24th June 2021process automation troubleshooting
Mieke Dryepondt [SLC] [DevOps Advocate]4.26K 24th June 2021 0 Comments
After a DMA update (internal build) an existing setup using Process Automation no longer works.
How do we start to debug? Where to look?
The setup uses a permanent booking with a specific process.
This process needs to start on-demand. To do this an Automation script exists to generate and throw a token.
All of this was working fine and was not changed.
In an info event I can see that the automation script to throw the token runs, but nothing happens after this.
Where do I start looking to get an idea of what is going wrong?
DMA version:
Prev: 10.1.2.0-9839-20210115-internal
New: 10.1.7.0-10523-20210616-release
Mieke Dryepondt [SLC] [DevOps Advocate] Selected answer as best 24th June 2021
Miguel Obregon [SLC] [DevOps Catalyst]23.67K Posted 24th June 2021 0 Comments
Hi Mieke,
When a PA workflow is not working, we start debugging this issue by checking the following items:
  • Are the queue elements correctly configured? Check if the parameter 'Resource Pool' is pointing to a valid resource pool. I remember that we had an issue that we lose this configuration after a DMA restart. This has been fixed since PA 1.2.1
  • Is the Resource Pool correctly configured? Check that all the resource pools that will be used in your PA workflow contains the property 'ProcessAutomation' set to True. This requirement is mandatory since PA 1.2.2
  • Are you using gateways? Can you double check that all the rules are correctly configured? Can you also double check that the node property 'PA_FunctionType' has been set to 'Gateway'?
  • Can you try creating a booking and double check that all the nodes contains resources that can be selected?
  • If the manual booking has been triggered correctly, can you check double on which queue element the tokens are getting stuck? When tokens are stuck, you will see them listed in the table 'Touking Routing'.
Log files:
  • Booking log file: If you have already a permanent booking running, check the booking log file if there are issues related to the booking life cycle.
  • Script log file (SLAutomation.txt): This log file will give you additional information if there is an issue in the profile load scripts or the SRM_LSO_ProcessAutomation script
  • Queue element log files: These log files will give you additional information in case there are issue with the token handling
Miguel Obregon [SLC] [DevOps Catalyst] Answered question 24th June 2021
