How to create elements for Riedel & Calrec devices
Solved2.26K views7th July 2023
Yuki Arakawa(3496) 荒川 祐貴 [DevOps Advocate]945 7th March 2023 0 Comments
For the demo I used the Riedel and Calrec device drivers to create the elements, but I am getting timeouts.
The devices exist correctly.
Products include:
Riedel / RSP 1200
Riedel / Artist1024
Riedel / Artist System Info (provided by TV2 Norway)
Calrec / Artemis
The drivers used are as follows
These do not seem to be accompanied by a Help page.
Riedel_Communications_Artist_128
Riedel_Communications_Artist_SNMP
Riedel_Communications_RSP_1200
Calrec_Artemis
I would like to know how to use each driver.
Hideyuki Imaida [DevOps Member]500 Posted 8th March 2023 1 Comment
Hi Yuki-san,
Regarding Riedel, 'Riedel_Communications_Artist_128' communicates with RRCS running on the external server. (Not Riedel HW)
Also, 'Riedel_Communications_Artist_SNMP' communicates with ArtistSnmpAgent.
So you should prepare external server with these applications.
Yuki Arakawa(3496) 荒川 祐貴 [DevOps Advocate] commented 28th March 2023
Thanks for the response.
It appears that Artist’s external server is using third party software.
I believe it will probably be a new development.
