How to create an AlarmFilter for alarm properties?
Solved3.21K views20th April 2023alarmFilter alarmrepository alarms SendSLNetMessage
Sebastian Ulloa [SLC] [DevOps Advocate]2.30K 19th April 2023 0 Comments
Hello,
I'm trying to get the history alarms based on a time range and a property value. I created the following AlarmFilter but it doesn't seem to be working:
var alarmFilterByProperty = new AlarmFilterItemString(AlarmFilterField.PropertyValue, propertyName, AlarmFilterCompareType.Equality, new[] { propertyValue });
var alarmFilter = new AlarmFilter { FilterItems = new AlarmFilterItem[] { alarmFilterByProperty, }, };
Is there something that I'm missing in the filter? Or may the problem be in the SLNetMessage (I'm using GetAlarmDetailsFromDbMessage instead of the AlarmRepository)?
Sebastian Ulloa [SLC] [DevOps Advocate] Selected answer as best 20th April 2023
Wouter Demuynck [SLC] [DevOps Advocate]7.04K Posted 20th April 2023 1 Comment
What property name are you using? Be aware that for AlarmFilterField.PropertyValue, the property name should have a prefix indicating the source of the property, e.g. "alarm.xxxx" ,"element.xxxx", "view.xxxx" or "service.xxxx"
Sebastian Ulloa [SLC] [DevOps Advocate] Posted new comment 20th April 2023
Sebastian Ulloa [SLC] [DevOps Advocate] commented 20th April 2023
I was missing the AlarmFilterField, thanks for adding the different prefixes.
