How to create an AlarmFilter for alarm properties?
Solved4.08K views20th April 2023alarmFilter alarmrepository alarms SendSLNetMessage
Sebastian Ulloa [SLC] [DevOps Advocate]2.34K 19th April 2023 0 Comments
Hello,
I'm trying to get the history alarms based on a time range and a property value. I created the following AlarmFilter but it doesn't seem to be working:
var alarmFilterByProperty = new AlarmFilterItemString(AlarmFilterField.PropertyValue, propertyName, AlarmFilterCompareType.Equality, new[] { propertyValue });
var alarmFilter = new AlarmFilter { FilterItems = new AlarmFilterItem[] { alarmFilterByProperty, }, };
Is there something that I'm missing in the filter? Or may the problem be in the SLNetMessage (I'm using GetAlarmDetailsFromDbMessage instead of the AlarmRepository)?
Sebastian Ulloa [SLC] [DevOps Advocate] Selected answer as best 20th April 2023
Michaël Pincket [SLC] [DevOps Advocate]2.13K Posted 20th April 2023 1 Comment
Hi Sebastian,
This syntax looks correct. Do note that you should use Type.Name as propertyName e.g. Alarm.Level. Not sure if this is the case.
It should not be a problem to use the GetAlarmDetailsFromDbMessage as Cube uses the same message to load the history tabpages in the alarmconsole.
Sebastian Ulloa [SLC] [DevOps Advocate] Posted new comment 20th April 2023
Sebastian Ulloa [SLC] [DevOps Advocate] commented 20th April 2023
That was indeed what I was missing. I was not including the Type to the propertyName.
Thank you!
