How to correctly format multipart/form-data request body for HTTP session
Solved3.78K views29th August 2023HTPP Multipart/from-data
Julian Yepe [SLC] [DevOps Member]316 15th August 2023 0 Comments
I am trying to send a POST HTTP request with Content-Type=multipart/form-data and I keep getting this error response: (status code: HTTP/1.1 400 Bad Request), returned VT_BSTR : {"errors": [{"message": "Multipart Request should be correctly formatted (1=name, 2=key)"}]}.
I have added screenshots from what the request payload and request headers look like when ran from swagger editor, screenshot of the HTTP session i have defined in the protocol.xml, and a screenshot of the of the request being logged by the element. Does anyone know what the issue could be?
Julian Yepe [SLC] [DevOps Member] Selected answer as best 29th August 2023
Floris Cockaerts [SLC] [DevOps Member]2.43K Posted 16th August 2023 1 Comment
Hi Julian,
I believe the boundary in your body is wrong. Comparing with this page: Multipart Requests (swagger.io) you can see that the boundary is prefixed with two dashes every time it is used, and suffixed with another two dashes at the end.
Counting the dashes in your header definition, there seem to be 29, and your body contains 29 rather than 31 dashes.
I made a protocol for a similar question here: https://github.com/FlorisCO/Dojo-HttpPostCsv/blob/RC/protocol.xml
Julian Yepe [SLC] [DevOps Member] commented 25th August 2023
Hi Floris,
Changing the dashes to two worked. Thank you for your help.
