How to correct Timeout Element?
Solved1.16K views3rd December 2024elements timeout
naveen joshi114 2nd December 2024 0 Comments
My PIRD(Ericsson) ping is coming but still it is showing in timeout state?
It is getting open in web.
What are the other parameters can i check?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 3rd December 2024
Felix Wesemeier [DevOps Catalyst]2.51K Posted 2nd December 2024 4 Comments
Hi Naveen,
first you can have a look if there is some communication error when looking into DataMiners stream viewer.
Right Click Element>View>Steam Viewer
Connecting to an element using Stream Viewer | DataMiner Docs
naveen joshi commented 2nd December 2024
yes i checked there it was showing error!
Felix Wesemeier [DevOps Catalyst] commented 2nd December 2024
Were you able to resolve it?
If not, what is the error message and what type of communication is used (HTTP/SNMP etc.)?
Thanks Felix
it is resolved.
Good to hear
