How to check loglevel and/or logtype in QActions ?
Solved2.01K views6th June 2024
Cristel Van Landeghem [DevOps Advocate]468 2nd April 2024 0 Comments
In 10.2 loglines are truncated after little more than 5000 characters.
The only solution to log info > 5000 is - according to https://community.dataminer.services/question/logging-in-10-2-loglines-are-truncated-afterlittle-more-than-5000-characters-how-to-avoid-that/ - to implement a loop in which 5000 characters are logged consequently.
To do that I like to get the current loglevel and/or logtype, so that only in debug level mode, this loop needs to be executed.
Something like:
if (protocol.LogType == LogType.DebugInfo)
loop in which   protocol.Log(reqString.Substring(i,j), LogType.DebugInfo, LogLevel.Level1);
else
protocol.Log(reqString, LogType.Allways, LogLevel.LogEverything);
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 6th June 2024
Floris Cockaerts [SLC] [DevOps Member]2.43K Posted 8th April 2024 0 Comments
Hi Cristel,
The length limit of a single log statement can be a hindrance in test scenarios, and perhaps a different storage location may be needed if investigation this amount of data is required, as the logging is intended for checking the status of a process or get a stack trace of an exception.
That being said, the log levels are not accessible as Tom W. mentioned earlier, but it is something we are likely going to add as device communication is migrating to QActions with the use of middlewares and DLLs that provide a communication API. There is currently no timeline for this, but more requests and good use-cases will likely bump this up in priority.
Floris Cockaerts [SLC] [DevOps Member] Answered question 8th April 2024
