How to check loglevel and/or logtype in QActions ?
Solved1.70K views6th June 2024
Cristel Van Landeghem [DevOps Advocate]468 2nd April 2024 0 Comments
In 10.2 loglines are truncated after little more than 5000 characters.
The only solution to log info > 5000 is - according to https://community.dataminer.services/question/logging-in-10-2-loglines-are-truncated-afterlittle-more-than-5000-characters-how-to-avoid-that/ - to implement a loop in which 5000 characters are logged consequently.
To do that I like to get the current loglevel and/or logtype, so that only in debug level mode, this loop needs to be executed.
Something like:
if (protocol.LogType == LogType.DebugInfo)
loop in which   protocol.Log(reqString.Substring(i,j), LogType.DebugInfo, LogLevel.Level1);
else
protocol.Log(reqString, LogType.Allways, LogLevel.LogEverything);
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 6th June 2024
Tom Waterbley [SLC] [DevOps Enabler]10.21K Posted 2nd April 2024 0 Comments
Hi Cristel,
I'm not aware of a method to know the current log level of an element. In some situations that could indeed be useful. It may be possbile to retrieve this information through an SLNet message.
However, the impact on performance of such small loop will probably be negligible. The loglevel that is provided in the method call is already being compared by DataMiner with the current setting and is only writted to the file when necessary.
