How to Back Up and Restore a DaaS System in Case of Decommissioning?
Solved2.80K views16th December 2024backup DaaS
KinetiMinds Tech [DevOps Advocate]272 12th December 2024 0 Comments
I’d like to know the best way to back up my DaaS system to ensure I can restore it later if my DataMiner credit expires and the system gets decommissioned. Are there any specific tools or processes I should follow to make this seamless?
KinetiMinds Tech [DevOps Advocate] Selected answer as best 16th December 2024
Debeuf Klaas [SLC] [DevOps Member]1.97K Posted 16th December 2024 0 Comments
I'm afraid that we don't support this full system backup at the moment for decommissioned DaaS systems.
The VM Backups are also removed when the system is fully decommissioned(after 10 days).
Regards,
