How to Back Up and Restore a DaaS System in Case of Decommissioning?
Solved1.91K views16th December 2024backup DaaS
KinetiMinds Tech [DevOps Advocate]218 12th December 2024 0 Comments
I’d like to know the best way to back up my DaaS system to ensure I can restore it later if my DataMiner credit expires and the system gets decommissioned. Are there any specific tools or processes I should follow to make this seamless?
KinetiMinds Tech [DevOps Advocate] Selected answer as best 16th December 2024
Baptiste Pattyn [SLC] [DevOps Advocate]5.85K Posted 12th December 2024 1 Comment
Hi
we are taking backups of all systems to provide options for restore in case something goes wrong or the system is decommissioned. If you want to get access to such a backup you can always contact support and they will be able to provide one to you.
Note that the docs are currently not entirely correct and we will update them with this information.
Hope this helps you!
With kind regards.
Thomas Verschuere [SLC] [DevOps Member] Posted new comment 12th December 2024
Thomas Verschuere [SLC] [DevOps Member] commented 12th December 2024
Hi
The backup does does get deleted 10 days after the system is decommissioned. We only take backups from running systems.
