How to Back Up and Restore a DaaS System in Case of Decommissioning?
Solved1.96K views16th December 2024backup DaaS
KinetiMinds Tech [DevOps Advocate]218 12th December 2024 0 Comments
I’d like to know the best way to back up my DaaS system to ensure I can restore it later if my DataMiner credit expires and the system gets decommissioned. Are there any specific tools or processes I should follow to make this seamless?
KinetiMinds Tech [DevOps Advocate] Selected answer as best 16th December 2024
Debeuf Klaas [SLC] [DevOps Member]1.78K Posted 12th December 2024 1 Comment
Hi KinetiMinds,
You can order extra credits to keep your system alive, see Order DataMiner Credits.
If you need to take a backup of your elements or services only, you can use Exporting and Importing.
Regards,
KinetiMinds Tech [DevOps Advocate] Posted new comment 12th December 2024
KinetiMinds Tech [DevOps Advocate] commented 12th December 2024
Dear Debeuf,
Thanks for your response.
I understand the option to order extra credits, but my concern is about preparing for a scenario where my current DaaS system gets decommissioned. In such a case, I need a full system backup—not just the elements and services, but also the users, protocols, configurations, and any other system-wide settings.
Could you please advise if there’s a way to perform a comprehensive backup that would allow me to fully restore my system to a new DaaS instance in the future?
