How to associate failover with a dashboard
348 views30th October 2025
ISRAEL FARFAN BETANZOS26 29th October 2025 0 Comments
Hello everyone,
Could you give me some ideas for creating a dashboard in LCA for failover monitoring? Is monitoring even possible? We recently had an incident where the local host where the dataminer was running went down and wasn't visible to operations. Therefore, we want to provide visibility into the failover behavior.
thanks to all
Jordy Bekaert [SLC] [DevOps Advocate] Answered question 30th October 2025
Jordy Bekaert [SLC] [DevOps Advocate]2.03K Posted 30th October 2025 1 Comment
Hi Israel,
The Generic Failover Status connector might be a good starting point then, which allows you to activate monitoring and trending on the failover state.
ISRAEL FARFAN BETANZOS Posted new comment 3rd November 2025
ISRAEL FARFAN BETANZOS commented 3rd November 2025
Thank you very much Jordi, I will start working with your suggestion.
