How to apply a table parameter filter on index instead of display-key / naming key?
Solved2.98K views17th March 2021filter index service template table rows
Jeroen Nietvelt [SLC] [DevOps Member]1.39K 17th March 2021 0 Comments
When configuring your service template and you want to filter out specific parameters (in my case rows from table parameters) from the included element instead of the entire element, would someone know if its possible to force the filter to be applied on the index instead of the display-key / naming value?
Jeroen Nietvelt [SLC] [DevOps Member] Selected answer as best 17th March 2021
Ive Herreman [SLC] [DevOps Enabler]14.78K Posted 17th March 2021 1 Comment
Hi Jeroen,
This can be achieved by adding ^pk^ in front of your filter.
e.g.
Jeroen Nietvelt [SLC] [DevOps Member] Posted new comment 17th March 2021
Jeroen Nietvelt [SLC] [DevOps Member] commented 17th March 2021
Thanks Ive, I’ll get right on it! The quick feedback is much appreciated.
