How to add help document for confluence and sharepoint as it SAML login?
Solved987 views9th September 2025
Apurva Tandon [DevOps Advocate]1.73K 19th March 2025 2 Comments
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 9th September 2025
Marieke Goethals [SLC] [DevOps Catalyst] commented 28th March 2025
Hi Apurva,
Could you clarify your question? What kind of help document do you want to add and where?
Marieke Goethals [SLC] [DevOps Catalyst] commented 9th September 2025
Marieke Goethals [SLC] [DevOps Catalyst]7.75K Posted 27th June 2025 0 Comments
Hi Apurva,
I see that this question has been inactive for some time. Have you found a solution for this yet? If yes, could you select this answer to indicate that no further follow-up is needed? Or if not, could you elaborate your question a little?
