How should the column array be structured for NotifyProtocol(193) if primary key is not at idx=”0″?
24 views3 hours agoFillarray
Jason Wan [SLC] [DevOps Advocate]368 7 hours ago 0 Comments
Hi everyone,
I am working on a connector where a table's primary key was changed from index="0" to another column index in <ArrayOptions> (while keeping the existing <ColumnOption idx="..."> order unchanged).
For example, suppose a table (PID 1000) has 4 columns, and the primary key is changed from idx="0" to idx="2":
<ArrayOptions index="2">
<ColumnOption idx="0" pid="1001" type="retrieved" options="" />
<ColumnOption idx="1" pid="1002" type="retrieved" options="" />
<ColumnOption idx="2" pid="1003" type="retrieved" options="" /> <!-- Primary Key -->
<ColumnOption idx="3" pid="1004" type="retrieved" options="" />
</ArrayOptions>
When filling this table using protocol.NotifyProtocol(193 /*NT_FILL_ARRAY*/, new object[] { 1000, true }, tableContent):
What should the tableContent object[] look like so that both the primary key (idx="2", PID 1003) and the column at idx="0" (PID 1001) are populated into their respective columns?
1. If I pass [col1001, col1002, col1003_PK, col1004], NotifyProtocol(193) treats the first element (tableContent[0]) as the primary key (PID 1003), which in the current situation is wrong, as the primary key should be col1003.
2. If I pass [col1003_PK, col1001, col1002, col1004], it also seems incorrect, as the position is wrong right now. (now col1001 is in col1002's position and col1002 is in col1003 position...)
3. Another option will be [col1003_PK, col1001, col1002, col1003_PK, col1004]
I tried the 3rd option, and it seems to work. What is the correct way to fill the table in this situation?
Thanks in advance!
Tiago Pina [SLC] [DevOps Member] Answered question 3 hours ago
Tiago Pina [SLC] [DevOps Member]526 Posted 3 hours ago 0 Comments
Hi Jason
This question has come up before. Check this out Is it possible to use an ArrayOptions tag with an index different than 0? - DataMiner Dojo
Regards
