How “flexible” is Dataminer in terms of being able to customize SNMP NB interface data?
Solved2.75K views19th July 2023alarms
7
Bruno Sousa [DevOps Member]669 25th March 2021 0 Comments
Hello
I was wondering how flexible is Dataminer in the matter of being able to customize the alarms that arrive to the platform and send them to other 3rd party through it's NB interface?
Suppose we want to change messages and give more "intelligence" than just forwarding "pure" and "raw" alarms.
Any features / suggestions? How flexible is the platform?
Are the "information templates" feature useful for this?
Thank you.
Best regards
Bruno Sousa
Roger Bijos [SLC] [DevOps Member]455 Posted 26th March 2021 0 Comments
Bruno,
Euler went to the heart of the matter. Processing "raw" alarms is not enough and there are multiple methods to augment content and pattern detections in DataMiner.
The next step is to understand the context in which to enrich the information in DataMiner as well as trigger actions such as share contextual information to other systems, via API, ticket gateway, dashboards, teams, etc.
We will be glad to link you with one of our SMEs (Subject Matter Experts)
Abs,
Roger
Roger Bijos [SLC] [DevOps Member] Answered question 26th March 2021
