How does “Keep me logged in” feature actually work?
Solved1.57K views4th July 2023login page
Jari Suni [DevOps Member]74 1st June 2023 0 Comments
Hi there,
It seems that users have to repeatedly log into the web app even though the selection below has been made on the login page.
How does this “Keep me logged in” feature actually work? Is there a time limit based on cookies (or similar) for how long the login is valid?
Wim Bruynooghe [SLC] [DevOps Advocate]6.78K Posted 1st June 2023 2 Comments
This will save an authentication key to the “local storage” of the web browser. Anything saved there has no expiration time. Unless you open the page in a “private” or “incognito” tab, in that case it does get cleared when closing the page.
Matthijs Favorel [SLC] [DevOps Advocate] commented 2nd June 2023
Hi Wim,
I did a couple of tests and the “DMACookie” in local storage is removed when reconnecting to Dashboards for example after an IIS restart or IIS recycle. As IIS is recycled automatically every night, is it expected that this “keep me logged in” function is reset every night?
Wim Bruynooghe [SLC] [DevOps Advocate] commented 13th June 2023
There is a software issue which caused that the connection only got restored once, as the cookie then got removed after a reconnect. We have a fix ready.
Restarting IIS or IIS recycling should not impact this.
