How does HeaderTrailerLink Data Forwarding work?
Solved2.86K views23rd February 2023data forwarding headerTrailerLink SLPort smart-serial
Stijn Declerck [SLC] [DevOps Advocate]834 9th February 2023 0 Comments
What happens when option 4 'HeaderTrailerLink' (see link) for data forwarding is defined in a smart-serial protocol?
https://docs.dataminer.services/develop/devguide/Connector/ConnectionsSmartSerialDataForwarding.html
Use case: the connector should receive a response from the device, but it doesn't seem to be forwarded. Therefore, I enabled the logging in SLPort.txt (1) to see the incoming data for that connection and also used Wireshark (2) for more information.
The Wireshark capture shows the request is sent to the device and the response is indeed received by DataMiner, divided in 4 packets. The logging in SLPort.txt also shows the response is received, but the data is divided into 2.
Why is the first response packet shown seperatly in the logging and why are the other 3 packets combined? Could this be the reason the response isn't forwarded?
(1)
2023/02/09 15:08:28.961|SLPort.exe 10.2.2235.1626|19532|14676|CSmartIP::ProcessIncomming
|DBG|4|Incoming data from 10.128.13.150:5554 (total length: 1460 bytes)
2023/02/09 15:08:28.963|SLPort.exe 10.2.2235.1626|19532|14676|CSmartIP::ProcessIncomming
|DBG|4|Incoming data from 10.128.13.150:5554 (total length: 3894 bytes)
(2)
Stijn Declerck [SLC] [DevOps Advocate] Selected answer as best 23rd February 2023
Stijn Declerck [SLC] [DevOps Advocate]834 Posted 23rd February 2023 0 Comments
SLPort scans the incoming data stream for the defined headers and trailers. Once a header is detected, SLPort will only search for the corresponding linked trailer. It will disregard any other headers or trailers within the data stream, even the same header will be skipped. Once the trailer is found, SLPort will forward the data between the header and trailer, including both the header and trailer themselves, to SLProtocol. Any data outside of the header-trailer matches will be discarded.
