How does HeaderTrailerLink Data Forwarding work?
Solved2.60K views23rd February 2023data forwarding headerTrailerLink SLPort smart-serial
Stijn Declerck [SLC] [DevOps Advocate]824 9th February 2023 0 Comments
What happens when option 4 'HeaderTrailerLink' (see link) for data forwarding is defined in a smart-serial protocol?
https://docs.dataminer.services/develop/devguide/Connector/ConnectionsSmartSerialDataForwarding.html
Use case: the connector should receive a response from the device, but it doesn't seem to be forwarded. Therefore, I enabled the logging in SLPort.txt (1) to see the incoming data for that connection and also used Wireshark (2) for more information.
The Wireshark capture shows the request is sent to the device and the response is indeed received by DataMiner, divided in 4 packets. The logging in SLPort.txt also shows the response is received, but the data is divided into 2.
Why is the first response packet shown seperatly in the logging and why are the other 3 packets combined? Could this be the reason the response isn't forwarded?
(1)
2023/02/09 15:08:28.961|SLPort.exe 10.2.2235.1626|19532|14676|CSmartIP::ProcessIncomming
|DBG|4|Incoming data from 10.128.13.150:5554 (total length: 1460 bytes)
2023/02/09 15:08:28.963|SLPort.exe 10.2.2235.1626|19532|14676|CSmartIP::ProcessIncomming
|DBG|4|Incoming data from 10.128.13.150:5554 (total length: 3894 bytes)
(2)
Stijn Declerck [SLC] [DevOps Advocate] Selected answer as best 23rd February 2023
Jens Vandewalle [SLC] [DevOps Advocate]10.08K Posted 9th February 2023 1 Comment
Hi Stijn,
  1. Are you using header and trailer or only trailer with the HeaderTrailerLink option?
  2. In case of the latter, is it possible that the first package already contains the trailer?
Stijn Declerck [SLC] [DevOps Advocate] Edited comment 10th February 2023
Stijn Declerck [SLC] [DevOps Advocate] commented 10th February 2023
Hi Jens,
I am using both a header and a trailer.
Checked the response and the trailer does not appear in the first part of the data.
I also discovered that another response from the same request (almost similar data) does get forwarded. It seems arbitrary to me, but I probably lack some information.
