How do I create a Protocol write Param of with a type of string that will allow text containing rn
Solved1.64K views12th October 2023
Mark Smith82 6th October 2023 0 Comments
When I use the UI to paste text into the field that contains \r\n, it just takes the text up to the the first \r\n and seems to be treating the \r\n as a delimiter. Is there an option that I can specify to allow it to take the whole string including the \r\n?
I have looked at the protocol API to try to find some options and I have tried adding dimensions to the write param to make it multi line, but it is still displayed as a single line.
<Param id="2600" trending="false">
<Name>configDetails</Name>
<Description>config Details</Description>
<Information>
<Subtext>The Config that will be updated.</Subtext>
<Includes>
<Include>time</Include>
<Include>range</Include>
<Include>steps</Include>
<Include>units</Include>
</Includes>
</Information>
<Type>read</Type>
<Interprete>
<RawType>other</RawType>
<Type>string</Type>
</Interprete>
<Display>
<RTDisplay>true</RTDisplay>
<Positions>
<Position>
<Page>Config Details</Page>
<Row>0</Row>
<Column>1</Column>
</Position>
</Positions>
</Display>
<Measurement>
<Type lines="40">string</Type>
</Measurement>
</Param>
<Param id="2605" setter="true">
<Type options="dimensions=5,1">write</Type>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
<Positions>
<Position>
<Row>0</Row>
<Column>0</Column>
</Position>
</Positions>
</Display>
<Measurement>
<Type options="hscroll">string</Type>
</Measurement>
</Param>
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 12th October 2023
Floris Cockaerts [SLC] [DevOps Member]2.43K Posted 9th October 2023 0 Comments
Hi Mark,
It looks like the lines option is only applicable to the read parameter at the moment. Multiline parameters can be displayed when the data is received through any other means, like polling or a parameter set by a QAction. However, the cube UI seems to trim multiline content that gets pasted into a write parameter field by design.
I can't speak to why it currently is this way, so I'd like to forward you to your point of contact or DataMiner Feature Suggestions - DataMiner Dojo for a new software feature request.
