How can I hide an interactive automation script result window
Solved1.51K views20th March 2024automation scipt Visio
Stijn Declerck [SLC] [DevOps Advocate]802 20th March 2024 0 Comments
Hi all,
Can I hide the result window (see below) of an interactive automation script that is triggered from a visio? I already found the option “NoConfirmation” to trigger the script without this window, but the feature to not show it after execution only applies to non-interactive scripts it seems.
Stijn Declerck [SLC] [DevOps Advocate] Selected answer as best 20th March 2024
Jarno Lernou [SLC] [DevOps Enabler]5.66K Posted 20th March 2024 1 Comment
Hi Stijn,
I think you need another option: CloseWhenFinished
Reference: Linking a shape to an Automation script | DataMiner Docs
Kind Regards,
Jarno
Stijn Declerck [SLC] [DevOps Advocate] Posted new comment 20th March 2024
Stijn Declerck [SLC] [DevOps Advocate] commented 20th March 2024
Can’t believe I didn’t spot that, thanks!
