How can I display a parameter from an element in a Dashboard?
Solved1.84K views26th January 2022Dashboard App
Daniela Oliveira [SLC] [DevOps Member]356 25th January 2022 0 Comments
I’d like to add in a dashboard both the read and write parameters that I have available in an element.
In this case the W parameter is a dynamic discrete.
How can I mimic what is below in a dashboard?
Please have in mind that the list is filled in by using a dynamicId
Daniela Oliveira [SLC] [DevOps Member] Selected answer as best 26th January 2022
Miguel Obregon [SLC] [DevOps Catalyst]23.97K Posted 25th January 2022 2 Comments
Hi Daniela,
Maybe there is another way, but a possible option is using a ‘Parameter page’ component. You can display a page from an element in a dashboard:
The drawback is that you will display all the parameters from the page.
Another option is using the ‘Visual Overview’ component to display the overview assigned to the element.
Pieter Van Compernolle [SLC] [DevOps Enabler] Posted new comment 26th January 2022
Daniela Oliveira [SLC] [DevOps Member] commented 26th January 2022
Thanks Miguel!
Actually in our use case we need to display an entire page anyway, the paremeter mentioned in the question was just one of the parameters we’d like to display from a page.
This is enough for us.
Pieter Van Compernolle [SLC] [DevOps Enabler] commented 26th January 2022
Please be aware that control functionality (like parameter sets) is not one of the main objectives for our dashboards application.
It is a main objective for our user-definable apps environment (currently in soft-launch and expected to be released in one of the 10.2.x features releases). So at some point you might need to move from a dashboard to a user definable app in order to still have the parameter sets in your page component.
