How can i connecting to any device and create dashboard??
Solved2.66K views19th July 2023#agent #dataminer #cube
Motoki Orikasa122 30th June 2023 0 Comments
Hey everyone,
I was able to access the Dataminer Agent using Cube.
I would like to connect to the device as soon as possible, but I don't know where to start.
Please advise.
Johan Hallez [SLC] [DevOps Member]74 Posted 30th June 2023 4 Comments
Hi Motoki,
Further to the comment of Baptiste, I have now made the Lawo V_matrix connector available for you as trial. you should now be able to download it via catalog. If you have any other connectors you like to test, you can request this via an email to the DataMiner Licensing Group <dataminer.licensing@skyline.be>
Johan Hallez [SLC] [DevOps Member] Posted new comment 30th June 2023
Motoki Orikasa commented 30th June 2023
thanks Johan!
I can’t find the V-matrix Protocol in Protocols & templates,,
Perhaps I need to download the V-matrix ProtocolFile from the Dataminer website and then upload it to DMA….. is this correct?
Johan Hallez [SLC] [DevOps Member] commented 30th June 2023
Hi Motoki,
that is correct. you can browse to https://catalog.dataminer.services/ and if you search for Lawo V_matrix, you will see that you can deploy. if you hit the button, it will be installed on your system and then you will be able to use it
Hi Johan,
I just accessed the catalog site, but it is marked No License there….hmmmm
Hi Motoki,
before you will be able to benefit from the cloud functionalities (catalog is one of them), you will need to connect to dataminer. services first. you can find the instructions on how to connect here: https://docs.dataminer.services/user-guide/Cloud_Platform/Connecting_to_cloud/Connect_to_dataminer_services.html
You are viewing 1 out of 5 answers, click here to view all answers.
