How can i connecting to any device and create dashboard??
Solved3.53K views19th July 2023#agent #dataminer #cube
Motoki Orikasa122 30th June 2023 0 Comments
Hey everyone,
I was able to access the Dataminer Agent using Cube.
I would like to connect to the device as soon as possible, but I don't know where to start.
Please advise.
Amer Hodzic [DevOps Member]784 Posted 30th June 2023 0 Comments
To connect devices you must create a new element with a protocol of the device you want to connnect and give it the ip address making sure the dma is able to reach the device.
Dashboards must be done through the web app.
Amer Hodzic [DevOps Member] Answered question 30th June 2023
You are viewing 1 out of 5 answers, click here to view all answers.
