How add / move low code app between DMAs
Solved2.88K views20th September 2024LowCode
Juan Chavez514 30th April 2024 0 Comments
Hello Im trying to add/move/share a lowcode app to my other agents. Is there an SOP for this??
Arne Maes [SLC] [DevOps Member] Answered question 20th September 2024
Gilles Bara [SLC] [DevOps Advocate]7.48K Posted 30th April 2024 1 Comment
Sadly, there is no easy built-in solution to do this yet.
However, you can follow the same procedure as duplicating an app within the same system (which can now be achieved through the UI), but you don't have to change any guids, because the app will be unique already on your other agent. A problem though is that objects used in your app might not exist on your destination agent. A similar question was recently posted about that topic.
Note that this will take a duplicate, not sharing the original app. So changes in one agent will not be reflected on the other agent. Unless they are in a DMS of course, where apps are synched between all agents.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 2nd May 2024
Juan Chavez commented 30th April 2024
Thanks @gilles.bara appreciate the info. Will try these manual steps….
regards,
Juan
