Help with help / documantation
Solved2.28K views11th July 2023
Ken O'Connor686 23rd August 2022 0 Comments
Hello..
Can someone provide me with the Dataminer Help link regarding Alarm Groups and Alarm Suppression. I cant seem to find anything on this topic.
Jochen Dewachter [SLC] [DevOps Member]2.17K Posted 23rd August 2022 0 Comments
Grouping alarms can be done via correlation rules:
https://docs.dataminer.services/user-guide/Advanced_Modules/Correlation/correlation.html
Suppressing alarms can be done via masking:
https://docs.dataminer.services/user-guide/Basic_Functionality/Alarms/Working_with_alarms/Masking_and_unmasking_alarms.html
Or suppressing alarms can also be done via editing your alarm template:
https://docs.dataminer.services/user-guide/Basic_Functionality/Protocols_and_templates/Alarm_templates.html
