Help Defining HTTP API Error Handling in My First Driver
Solved1.73K views9th September 2025Connector error handling HTTP
Deema Mahmud32 4th March 2025 2 Comments
Hello Everyone,
I am currently developing my first driver, and I need some help with handling errors in my HTTP-based protocol. The API documentation defines an error response schema with only two parameters:
  • code (integer, optional)
  • message (string, optional)
However, there is no specific description of what these error codes or messages represent. Additionally, the default error response is labeled as "Invalid request" without further details.
My Questions:
  1. How should I define this error structure in my protocol?
    • What parameters do I need to capture from the API response?
    • How should I structure error logging and handling?
  2. How should I implement this in my protocol (from parameter to trigger to QAction)?
    • What’s the best way to handle this in a QAction or a trigger?
    • Should I create a dedicated error-handling QAction?
Any guidance on how to structure this properly would be greatly appreciated. Thanks in advance!
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 9th September 2025
Marieke Goethals [SLC] [DevOps Catalyst] commented 26th June 2025
Marieke Goethals [SLC] [DevOps Catalyst] commented 9th September 2025
frans siew [SLC] [DevOps Advocate]1.08K Posted 5th March 2025 0 Comments
Hi Deema,
      • the code to check if it is a valid http call and the content/error message
      • you could display the error message via the protocol.log (if using a qaction) alternatively could set an exception value to the parameter that the api response is updating
      • if you are already going to process the response in a QAction, you could check the HTTP code there. Since we do not know what is the HTTP code, you could test it by trying to send an invalid request to the device to check the HTTP code that it gives.
        Alternatively you could also to process the response only if your HTTP code is '200'
        if you are not going to process the response in a qaction, you could have an after trigger with a condition to check if you got an error and do any follow up action like setting an exception value to a parameter
        • you could create a generic error handling in the precompile QA to share code which would allow you to reduce duplicate code to process exceptions for other http calls
I hope these answers help
frans siew [SLC] [DevOps Advocate] Answered question 5th March 2025
