Have element timeout event trigger a critical alarm for the element?
Solved3.63K views16th November 2021alarm severity Correlation rule
Jeff Douglass870 12th November 2021 0 Comments
Is there a way to have an element go RED and trigger a Critical alarm for the element in timeout?
Thanks
Jeff Douglass Answered question 16th November 2021
Gelber Mahecha [SLC] [DevOps Enabler]2.03K Posted 12th November 2021 0 Comments
Hi Jeff,
You can use a correlation rule filtering the alarms by severity equals to TimeOut and then creating a new alarm with the critical level.
As a result, if the element goes into a timeout, the rule will create a new correlated critical alarm, and the element will show a red color.
Gelber Mahecha [SLC] [DevOps Enabler] Answered question 12th November 2021
