Handling parquet files in DataMiner Connectors and Automation Scripts
Solved447 views16th October 2026automation engine parquet protocols
7
Blake Smethers [SLC] [DevOps Advocate]1.29K 16th October 2026 0 Comments
I'm working on a connector that needs to convert CSV files into Parquets, but I can't get Parquet.Net or ParquetSharp to work. Does anybody know why this might be and how I can get around it?
Blake Smethers [SLC] [DevOps Advocate] Selected answer as best 16th October 2026
Bautista Solanet [SLC] [DevOps Advocate]1.36K Posted 16th October 2026 0 Comments
Hey Blake,
The reason why ParquetSharp fails is that ParquetSharp does not support x86 processes, which both SLScripting and SLAutomation are.
As for Parquet.Net, version 4.25.0 can work so long as you avoid certain compression styles as these will cause Parquet.Net to load a dependency that also does not support x86 processes. I recommend using Gzip compression as that is confirmed to be safe.
Also avoid naming columns with the JsonPropertyName Attribute as that can also cause that dependency to be loaded and cause issues.
These issues don't apply to GQI Ad Hoc DataSources as they run on a x64 process.
I hope this helps,
Bauti
