GX2 Optical Level – Motorola GX2-CM100 B
Solved1.86K views28th September 2023
Ricaurte Alvarado248 28th August 2023 0 Comments
Hello Team,
We want to know the formula or the calculate to get the optical level from GX2 Optical platform from the Driver Motorola GX2-CM100 B we know that Dataminer use this OIDs (1.3.6.1.4.1.1166.6.1.2.15.2.1.8 and 1.3.6.1.4.1.1166.6.1.2.15.2.1.19) to get the value but we dont know how dataminer convert the output in dBm values.
Best,
Ricaurte Alvarado Answered question 28th September 2023
Ricaurte Alvarado248 Posted 28th September 2023 0 Comments
Hello Arturo,
We found the method with the Software Visual Studio, but now we have more questions about the functions that use the case(62000) in QA3. Where can we find the function Calculations.CalculatedConvertedValue
oswPrimaryInputLevel[i] = Calculations.CalculateConvertedValue(Convert.ToString(((object[])oswColumns[1])[i])); // Primary Optical Analog Input Level
oswSecondaryInputLevel[i] = Calculations.CalculateConvertedValue(Convert.ToString(((object[])oswColumns[2])[i])); // Secondary Optical Analog Input Level
Best,
