GQI filter on multi-DomInstanceFieldDescriptor
Solved1.87K views9th March 2023GQI lowcodeapps
6
Ive Herreman [SLC] [DevOps Enabler]14.80K 2nd March 2023 0 Comments
Hi DoJo,
Is there a way that I could filter a list of DOM instances based on a match in a multi-DomInstanceFieldDescriptor field?
e.g. instances A and B have a link to an instance X.
I'd like to use the ID of instance X to filter out A & B.
Ive Herreman [SLC] [DevOps Enabler] Selected answer as best 9th March 2023
Pieter Van Compernolle [SLC] [DevOps Enabler]4.40K Posted 8th March 2023 0 Comments
Hi Ive,
While staying tuned for what's coming, you can maybe work around with an ad hoc data source accepting some input parameters (you can link those to feeds). In 10.3.4 you can use the new OnInit()?
