GQI filter on multi-DomInstanceFieldDescriptor
Solved1.74K views9th March 2023GQI lowcodeapps
6
Ive Herreman [SLC] [DevOps Enabler]14.79K 2nd March 2023 0 Comments
Hi DoJo,
Is there a way that I could filter a list of DOM instances based on a match in a multi-DomInstanceFieldDescriptor field?
e.g. instances A and B have a link to an instance X.
I’d like to use the ID of instance X to filter out A & B.
Ive Herreman [SLC] [DevOps Enabler] Selected answer as best 9th March 2023
Pieter Van Compernolle [SLC] [DevOps Enabler]4.39K Posted 8th March 2023 0 Comments
Hi Ive,
While staying tuned for what’s coming, you can maybe work around with an ad hoc data source accepting some input parameters (you can link those to feeds). In 10.3.4 you can use the new OnInit()?
10
Thomas Ghysbrecht [SLC] [DevOps Enabler]5.79K Posted 2nd March 2023 0 Comments
Hi Ive,
If the reference to the DomInstance is stored in a list, it is unfortunately not possible at the moment with GQI because it does not support filtering & displaying DOM fields with multiple values yet. Support should be coming in the future though, so stay tuned.
Thomas Ghysbrecht [SLC] [DevOps Enabler] Answered question 2nd March 2023
