Give feedback in Dashboard after failed Automation script
Solved2.02K views4th November 2021automation scipt Dashboard
Timothy Van Poucke [SLC] [DevOps Advocate]1.38K 3rd November 2021 0 Comments
I'm running an automation script from a dashboard (which is embedded in a Visio). When it fails, it will exit the script with ExitFail and a message explaining why it failed. I can see this in the logging in Cube:
But on the dashboard where I've started the script I get this:
I would like to give the user the same message as in the logging. Instead of that "null". Would anyone know how to achieve this?
Timothy Van Poucke [SLC] [DevOps Advocate] Selected answer as best 4th November 2021
Thomas Remmery [SLC] [DevOps Advocate]1.06K Posted 3rd November 2021 2 Comments
Hi Timothy, we were having similar issues in our project. This seems to be a software issue when lauching an script from Dashboards. To work around this, we just don’t use ExitFail, but rather ExitSuccess (even if it fails). I’m not sure if ExitSuccess logs to the information events. If not, I would create a method that logs the issue using engine.GenerateInformation and then calls engine.ExitSuccess.
Sebastiaan Dumoulein [SLC] [DevOps Enabler] commented 3rd November 2021
Have you already created a task for this? I don’t believe this is currently on our backlog.
Timothy Van Poucke [SLC] [DevOps Advocate] commented 4th November 2021
Task created, https://collaboration.dataminer.services/task/170348
