Getting all parameters and their values from Element in C#
Solved1.25K views3rd October 2024automation scripts
João Azevedo484 2nd October 2024 3 Comments
Hello, i need help with a function that will get all parameters of a Element and their values, and set it in another Element. If anyone can help me, I will be grateful!
e.g: I have element01 and element01_copy, thei have the same parameters but the copy need to get the values inserted from the original element.
Peter Geivaerts [DevOps Advocate] Answered question 3rd October 2024
Tom Waterbley [SLC] [DevOps Enabler] commented 2nd October 2024
Hi João, could you please elaborate what exactly you want to achieve? Is the element polling data from a device, or is it a virtual protocol. Does every read parameter also have a write parameter that can be set?
Depending on what you’re trying to do, element connections could be an option: https://docs.dataminer.services/develop/devguide/Connector/AdvancedInterElementCommunicationElementConnections.html.
João Azevedo commented 2nd October 2024
Hi Tom, you helped me with the question about cloning an element via C#, and now i need to get the parameters value of that original element and set it in the clone one.
E.g: Element01 has a parameter dummy1 with value 1, when i cloned the Element01 it created the Element01_clone and it come with the parameters from the original but not initialized. I want to set the same value of each parameters from the original element to the new one.
I tried find a function that count the number of parameters that the element have, but can’t find one.
Miguel Obregon [SLC] [DevOps Catalyst] commented 2nd October 2024
Hi Joao,
Could you let us know why you need element duplication? Maybe there is another DataMiner functionality that can help you with this requirement.
Peter Geivaerts [DevOps Advocate]308 Posted 3rd October 2024 0 Comments
If it's just about creating a new element with the exact contents of the original one there are automation scripts for this purpose available in the catalog.
Get all parameters and write to a file
RetrieveAllParams | Catalog (dataminer.services)
copy all parameters from file to element
SetAllParams | Catalog (dataminer.services)
Peter Geivaerts [DevOps Advocate] Edited answer 3rd October 2024
