GetAlarmDetailsFromDbMessage for active alarms only on automation script
Solved532 views12th August 2026Automation script GetAlarmDetailsFromDbMessage
Henri Martins [DevOps Advocate]916 12th August 2026 0 Comments
Hi.
I want to find all active alarms on my DMS on an automation script.  With "
a {
text-decoration: none;
color: #464feb;
tr th, tr td {
border: 1px solid #e6e6e6;
tr th {
background-color: #f5f5f5;
GetAlarmDetailsFromDbMessage" , we got all aalrmes on the DB (too mutch). Does it exist a function to get active alarms faster?
Thanks.
Henri Martins [DevOps Advocate] Selected answer as best 12th August 2026
Henri Martins [DevOps Advocate]916 Posted 12th August 2026 0 Comments
a {
color: #464feb;
tr th, tr td {
tr th {
GetActiveAlarmsMessage seem to be the good response for my question.
