Get First MAC in code rather than by using serVar
Solved1.80K views5th January 2022FirstMac users
Ladan Razeghi [DevOps Catalyst]1.09K 17th December 2021 0 Comments
Hi Guys
Can we check FirstMac of online user directly in protocol as soon as they are logged in to Dataminer rather than using SetVar value in visio?
Ladan Razeghi [DevOps Catalyst] Selected answer as best 5th January 2022
Pieter Van Compernolle [SLC] [DevOps Enabler]4.30K Posted 20th December 2021 4 Comments
I don’t think this is possible at the moment. But maybe you can share your use case and we can think along for alternatives.
For example use ‘ComputerName’ or ‘connection ID’ (instead of mac, based on CollaborationStatusEventMessages which are being sent when new connections are done)
Or forcing a default workspace for certain usergroups, so you can continue using ‘FirstMac’ in Visio.
Pieter Van Compernolle [SLC] [DevOps Enabler] Posted new comment 6th January 2022
Ladan Razeghi [DevOps Catalyst] commented 20th December 2021
Hi Pieter
As soon as a user logged in to Dataminer, we need to know what macAddress they are using so we show their desk is connected. This desk connection will allow them to do other actions.
We can do that by creating a button to connect desk on visio and use SetVar to get their MacAddress.
But I was wondering if we can reduce that click button step on visio and show desk is connected automatically inside code.
The reason that we need macAddress is because we use [firstmac] placeholder in visio to find out other connections to other elements/services in visio. I don’t know if we have any placeholder for ‘ComputerName’ or ‘Connection ID’ on visio which can help us out.
Pieter Van Compernolle [SLC] [DevOps Enabler] commented 20th December 2021
Ok I see Ladan,
Maybe you can work with a ‘Execute’ action on page level? This will prevent the need of a button (but will still require your users to open the card where the Visio is linked to, but I guess that is not a problem?).
see https://help.dataminer.services/dataminer/#t=DataMinerUserGuidepart_2visioConfiguring_a_page_to_update_parameters_on_session_variable_changes.htmXREF_66525_11_6_5_configuring&rhsearch=firstmac&rhsyns=
and
https://help.dataminer.services/dataminer/#t=DataMinerUserGuidepart_2visioLinking_a_shape_to_an_Automation_script.htm&rhsearch=firstmac&rhsyns=&rhhlterm=triggervaluechanged&ux=search
For example on ‘Page’ level in your Visio drawing, you can have this shape data:
Execute
Script:MyScript||MacParameter=[FirstMac]|||NoConfirmation|Trigger=ValueChanged
Options
ExecuteSetsOnInit
This config will execute the script with name ‘Myscript’ every time a user opens the card (no click on a button needed) and the mac will be filled in in the script parameter with name ‘MacParameter’.
As an alternative, you can work with a parameter set instead of a script.
Ladan Razeghi [DevOps Catalyst] commented 5th January 2022
Thank you Pieter I’ll test this. Our policy is to avoid scripts but I like to test this solution and maybe apply it if I get approval
Pieter Van Compernolle [SLC] [DevOps Enabler] commented 6th January 2022
If you don’t want to use a script, you can also work with a parameter set: see https://help.dataminer.services/dataminer/#t=DataMinerUserGuidepart_2visioConfiguring_a_page_to_update_parameters_on_session_variable_changes.htm
To what was you button linked originally?
