Get dataminer Host link, agent id and agent name using automation script
758 views1st September 2026agents Automation script DataMinerAgent
Baranisudha Murugesan [DevOps Member]1.19K 17th August 2026 0 Comments
There is a way to get list of agents available through DMS. But I want to find the particular agent from which the script is running. dms.GetAgent(int) method needs current agent id to be passed to fetch the details.
Is there any way to get Hostlink, agent Id and agent Name in which the automation script is deployed/accessed from?
Baranisudha Murugesan [DevOps Member] Changed status to publish 1st September 2026
Bautista Solanet [SLC] [DevOps Advocate]1.35K Posted 17th August 2026 2 Comments
Hello Baranisudha,
If you get the connection when you script is running, either through IEngine.GetUserConnection() or IDms.Communication.SlNetConnection, you can the ServerDetails from the connection. This object contains the ID, IP, and Name or the connected agent which the script is working on.
Here's the page in the docs for this object: Class ServerDetails | DataMiner Docs.
I hope this helps you,
Bauti
Bautista Solanet [SLC] [DevOps Advocate] Edited comment 1st September 2026
Baranisudha Murugesan [DevOps Member] commented 1st September 2026
I have got the agent details in this. Now i also need Host link to make the user navigate to the DMA from email. Is there any property to get Hostlink from IDms or engine objects?
Bautista Solanet [SLC] [DevOps Advocate] commented 1st September 2026
I believe that the IP address of the Agent will be your best bet to include a link, but I'm assuming that the IP might not be the preferred way to link the DMA. In that case, you could define a variable at the top of your code and set that to the Host Link of the DMS and configure it per system, or you could have a dictionary of links based on the DMS IDs
