Get Agent and Port for element
Solved396 views2nd February 2026Connector smart-serial
Timothy Van Poucke [SLC] [DevOps Advocate]1.38K 2nd February 2026 0 Comments
I have an element with a smart serial connection and a http connection.
<Type relativeTimers="true" advanced="smart-serial:Events Connection" communicationOptions="redundantPolling">http</Type>
Is there a way to get the Dataminer IP and port of the events connection in a QAction of this connector?
Context:
I need to send a message to the device
Body:
          "ServerIDs": ["****"],
          "EventsPushApiUrl": <IP address and port of DMA>,
          "DpiPushApiUrl": "",
          "NavePushApiUrl": "",
          "CaptionsPushApiUrl": "",
          "EasPushApiUrl": "",
          "StreamingMonitorPushApiUrl": ""
Thanks in advance
Timothy Van Poucke [SLC] [DevOps Advocate] Selected answer as best 2nd February 2026
Joey Vanhalst [SLC] [DevOps Advocate]2.13K Posted 2nd February 2026 0 Comments
For DM to act as server, you can configure as the ip as "any" and define the port in the element settings (see Configuring a smart-serial connection as a server | DataMiner Docs).
You will need to retrieve the ip of the agent hosting the element, and include the port defined in the element settings so the remote device knows the endpoint.
José Silva [SLC] [DevOps Enabler]1.91K Posted 2nd February 2026 0 Comments
Hi Timothy,
Maybe you can use this DATAMINER INFO to retrieve the IP address of DMA. I'm not sure if the port will also be there, but you can check
Hope this could help you
Kind regards,
José Silva [SLC] [DevOps Enabler] Edited answer 2nd February 2026
