Get Active alarms from dataminer cluster – automation script
Solved971 views18th April 2025Automation script get Alarms GQI
Baranisudha Murugesan [DevOps Member]1.16K 17th October 2024 2 Comments
I have created a GQI for getting overall alarms from DM. the methods i have referred need dma and element ids to get alarm for a particular element. but i want to get alarm for my DM cluster on the whole. do we have any documentation to refer this?
Marieke Goethals [SLC] [DevOps Catalyst] commented 28th January 2025
José Silva [SLC] [DevOps Enabler]1.91K Posted 17th October 2024 0 Comments
Hi Baranisudha,
It sounds like you're working on a GQI query in a dashboard or app. If you're looking to retrieve alarms for your entire DM cluster rather than for individual elements, I recommend checking out a similar topic that might be helpful: Dashboards - Get Active Alarms query - DataMiner Dojo
This resource should guide you through setting up the query you need.
Let me know if you need further assistance!
Kind regards,
