Generic Trap Receiver- Syslog function
Solved890 views27th February 2024
Ashwiny J K Anandan [DevOps Advocate]578 21st February 2024 0 Comments
Would like to further understand regarding the protocol: Generic Trap Receiver. Is this driver similar to Syslog? Where it can keep logs from multiple devices and users can filter the logs when needed?
Or is this driver specific to an element? we need to create multiple element in order to receive the SNMP trap ?
Ashwiny J K Anandan [DevOps Advocate] Selected answer as best 27th February 2024
Miguel Obregon [SLC] [DevOps Catalyst]22.20K Posted 21st February 2024 3 Comments
Hi Ashwiny,
I am not familiar with the Syslog connector, but I know a bit about the Generic Trap Receiver.
No, you can use the same element to receive traps from multiple devices.
The parameter Trap IP Sources accept multiple IP addresses:
Hope it helps!
Miguel Obregon [SLC] [DevOps Catalyst] commented 21st February 2024
This is also mentioned in the catalog:
https://catalog.dataminer.services/details/connector/833
Ashwiny J K Anandan [DevOps Advocate] commented 21st February 2024
Hi Miguel,
Thanks for the reply. Can we save these logs as file?
We are using protocol version 1.0.1.24.
In this link https://community.dataminer.services/use-case/generic-syslog-receiver/?hilite=Generic+Syslog+Receive, there is a column log messages and we can define the path to log file
The Generic Trap Receiver don’t support that functionality (define a path for exporting the content of the Trap table). However, you can manually export the content of the table by right clicking on the table:
https://docs.dataminer.services/user-guide/Basic_Functionality/Parameters/Types_of_parameters/Table_parameters.html?q=exporttable
