Generic Syslog Receiver – Received Messages not stored
Solved3.14K views22nd March 2024catalyst syslog
Joerg Stumpf [DevOps Advocate]231 18th March 2024 0 Comments
Hi Dojo
We have a Cisco Catalyst that is sending syslog messages to DataMiner (10.0.0.0-9589-CU7).
I can see the messages in Stream viewer, but the Received Raw Messages Table is still empty.
I configured the IP address of the switch as accepted IP address in the Edit dialog of the element and as IP Filter in the General settings.
Do I have to configure the structure (layout) of the syslog message?
Is there any documentation of the connector?
Any ideas?
Thanks Dojo
Joerg Stumpf [DevOps Advocate] Selected answer as best 22nd March 2024
Joerg Stumpf [DevOps Advocate]231 Posted 22nd March 2024 1 Comment
Hi Ive
I installed the quite old tool Visual Syslog and I can see, that the messages from the catalyst switch.
So it seems that a priority is submitted by the Catalyst switch.
Ive Herreman [SLC] [DevOps Enabler] Posted new comment 22nd March 2024
Ive Herreman [SLC] [DevOps Enabler] commented 22nd March 2024
That’s interesting.
I’ve sent you an email to initiate a more in-depth investigation.
